Does anyone know if the older DAC3 controller that was sold with PCDJ way back will work with Virtual DJ on a Mac with OS X El Capitan?
geposted Thu 06 Oct 16 @ 1:57 pm
Its midi compatible so I guess it could technically be mapped. If you are capable of figuring out how to map it then yeah. Though I would probably just buy a cheap controller than spend hours doing that if i was you.
geposted Thu 06 Oct 16 @ 2:04 pm
actually, isnt it the DMC2 Listed here...
https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
if so it should be natively supported.
geposted Thu 06 Oct 16 @ 2:27 pm
The DMC2 is not the DAC3. The DAC3 is still natively supported in VDJ 8, so it certainly will be in VDJ 7.
geposted Thu 06 Oct 16 @ 8:29 pm
