Topic: VDJ stops working
hi, looking some help. I have the latest version running and using denon sc2900 x2 units, every time I set up my laptop to use vdj, once the programme starts it will only run for a short while then stops and I get a message saying the programme has stopped working. can someone advise if this can be fixed. Cheers.
geposted Sun 09 Oct 16 @ 3:38 pm
Which sound card is used in the Audio setup of VirtualDJ ?
hi
I'm using the denon soundcard from the denon units
Uninstall the Denon ASIO drivers
Restart your computer and re-install drivers (check denon website to see if there is a new version)
With the Denon units connected, make sure your computer is not using the Denon sound cards as default.
Open VirtualDJ and Apply the audio configuration with the Denon drivers.
See if that resolves the issue.
@djdad, can you explain how updating the drivers might fix the issue? I may have a similar problem with my Presonus.
