Hi guys,
My auto mix panel won't stay open on DJ7. I have to take the pointer over to the extreme right to see it. When I move the pointer to the left it vanishes. Is there a way to make it visible all the time so I can quickly refer to it?
Thankyou
Thankyou
geposted Sun 23 Oct 16 @ 7:10 pm
You really should read the manual. It tells you how to use the software.
Click the padlock.
By the way, why are you still using version 7?
Click the padlock.
geposted Sun 23 Oct 16 @ 7:19 pm
Thanks for that . I'm using 7 because 8 won't run properly on my new Notebook Pro
geposted Sun 23 Oct 16 @ 7:31 pm
Please expand on "won't run properly".
If it's a new computer then VDJ 8 would be the better option. Not only does it get updated regularly (7 is no longer updated) but it's just better in lots of ways.
geposted Sun 23 Oct 16 @ 8:12 pm
Thankyou, I am sure you are right. My only issue with 8 (and I can't find a reference in the manual) is when I click on 'folders' to access my music from the desktop I get a message saying 'Not available in Appstore Edition'
geposted Mon 24 Oct 16 @ 9:48 am
That's because Apple have restricted features on that edition to comply with their appstore policies. Just download from here instead to bypass the restriction.
https://virtualdj.com/download/
geposted Mon 24 Oct 16 @ 9:54 am
PS. Incidentally I am new to Macs as previously I have always used PCs running MS Windows
geposted Mon 24 Oct 16 @ 9:56 am
