Not sure if this has been mentioned before...  I have used Virtual DJ for at least 3 years and I love it, occasionally a bride will give me a Do Not Playlist.  I would like to have a place to enter these that will notify me if I drag it to the player.  So I don't have to keep checking her list.
Thanks
    Thanks
geposted Sat 29 Oct 16 @ 4:05 pm
          You could just temporarily remove those tracks from your library, so they won't show in search results...
    geposted Sat 29 Oct 16 @ 4:20 pm
          make a playlist mark them as played
    geposted Sat 29 Oct 16 @ 6:38 pm
          Or send the do not play tracks to the recycle bin, [ensuring you have space to hold them] then restore them after the gig
    geposted Sat 29 Oct 16 @ 10:03 pm
          Crikey, a bit of imagination from the OP and you wouldn't have needed to post, you can colour your tracks, say red for the event, choose a column ie, album, comments or any other that are available and set either letters or digits to signify not to use... simples.
    geposted Sun 30 Oct 16 @ 7:02 pm
