Topic: Pre-Browsing the database
At the start of an evening of karaoke, it takes a few min to complete the first few searches. After that, results happen as i type. I'm assuming there's some kind cacheing going on. Is there a way to force VDJ to do this on startup without starting a search?
thanks
.dw
geposted Mon 31 Oct 16 @ 4:26 pm
Is your music located in an external hard drive?
geposted Mon 31 Oct 16 @ 5:52 pm
Do you have the date modified column visible in the browser? (If so, try to remove it and replace with the 'first seen' column)
geposted Mon 31 Oct 16 @ 7:24 pm
I JUST migrated to an external drive but the behavior existed when everything was on the internal.
geposted Mon 31 Oct 16 @ 8:22 pm
UPDATE - I've made that change in the browser. We'll see if that helps the next time i fire up the systen from skratch
I do have that column listed. i'll try that
thanks
.dw
