Hi!
Could we have a function to activate or deactivate the actions on the POIs?
- So that the actions programed on the POIs will or will not be executed.
- For all action-POIs at the same time (!)
- To decide to play the song regularly or with the programed actions.
geposted Sat 05 Nov 16 @ 3:46 am
use a variable as a switch, have the poi query the variable, yes perform the action, if no do nothing
just requesting makes me think you don't get it.
geposted Sat 05 Nov 16 @ 4:06 am
I get it, and I thought about that, too...
But somehow I think this is a little inconvenient way to solve it...
I use this a lot, and it just would be easier and time saving.
By the way:
It would be also nice if there was a query for tracks containing Action-POIs.
Or if there was a column in the browser which shows the number of actions in a track.
I am thinking of the inexperienced users...
Maybe they can program something easy with one single action or so... But not everybody can create queries with variables (as I know from those who work with VDJ in my region).
I think this would be a nice and easy but very effective und useful feature...
By the way:
geposted Sat 05 Nov 16 @ 3:23 pm
Apologies then, your wish makes a bit more sense now.
geposted Sat 05 Nov 16 @ 5:45 pm
No problem :)
Thank you!
P.s.:
As I thought about it again I would find it also useful to name a deck for the "POI-Actions-Switch".
For example:
deck 1 poi_actions on
and
deck 2 poi_actions off
Similar to almost all the other actions in VDJ.
I could use this for some transitions with acapellas or some scratch-techniques.
Thank you!
P.s.:
For example:
and
geposted Sat 05 Nov 16 @ 7:25 pm
