Topic: Couple issues with the latest build
dbrosPRO InfinityMember since 2009
I use a denon6000mk2 with windows 10. Most of the program was running smooth prior to latest build. I now notice the loop isn't working the same. When I try to loop it throws me back much further than the intended loop. A bigger issue was with my cross fader on the controller....when I would cross fade from left to right, the program cross fader would start going nuts and slide back and forth. Never had this issue in the past.
geposted Sat 05 Nov 16 @ 1:05 pm
Both issues resolved. Had a bleeding fader (used tuner spray, now it seems fine). For the loop, somehow I must have selected loop back mode. Turned it off, now it's fine
geposted Sat 05 Nov 16 @ 6:05 pm
