Topic: Rating command no longer works
In recent beta builds the rating hotkeys I had setup no longer function correctly.
rating +5 & browsed_file_color "cyan"
The color changes but the rating no longer works in that it does not tag the file rating.
geposted Thu 10 Nov 16 @ 5:59 pm
Remove the "+" symbol
geposted Thu 10 Nov 16 @ 6:12 pm
Makes no difference. The syntax no longer works.
geposted Fri 11 Nov 16 @ 6:05 pm
just done it here with 3514
rating 5
works
[the track has to be loaded]
geposted Fri 11 Nov 16 @ 6:15 pm
I've just figured out why it's not working. It has to be loaded to a deck first. I was trying to do it from the browser without a track loaded to a deck. D'OH!
One problem with this is that you can change the color of a different track (highlight another track while the first track is loaded) and it changes the color for the highlighted track BUT! The original loaded track gets the rating. This is highly confusing. Can you please change it to rate the highlighted track instead, so it matches browsed_file_color.
geposted Fri 11 Nov 16 @ 6:20 pm
Yeah this is really interfering with my workflow.
It goes like this.
Load track to deck 1 and play.
While deck 1 is playing look for next track in browser.
Load next track to mix in.
Hear track 1 is good or bad so highlight track and hit rating hotkey.
TRACK 2 GETS THE RATING INSTEAD (But it does change the color of the track)!
You can see this is a problem.
geposted Sat 12 Nov 16 @ 1:25 pm
I don't get your system 6 ratings many colours, it just doesn't make sense
anyway, just browse 2 folders before you use it
rating 5 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'green' & goto_last_folder & goto_last_folder
geposted Sat 12 Nov 16 @ 1:53 pm
I don't even know what that's doing but I want to rate and color the highlighted track in the browser no matter which track is currently playing. Simples.
I'm requesting a 'browsed_file_rate' command please.
geposted Sat 12 Nov 16 @ 2:34 pm
lincol2PRO InfinityMember since 2011
just highlight the track in the browser and press a smart button.
map this to the smart button:
rating 5 & browsed_file_color "cyan"
hope it helps.
geposted Sat 12 Nov 16 @ 2:54 pm
There is no such action at the moment, so feel free to add your request in our Wishes Forum
geposted Sat 12 Nov 16 @ 2:56 pm
DeadMan3000 wrote :
Simples.
So it appears, try it.
the one I just posted works if that is what he needs, and thanks to Sir locodog
geposted Sat 12 Nov 16 @ 2:58 pm
The one I posted gets the loaded file title - remix , searches for it and then marks the loaded track as a colour and a rating, then it flicks the browser back to where it was.
Pad page on the way.
geposted Sat 12 Nov 16 @ 3:08 pm
The above did not work. I got Norman to request a dev to add it and it says it was added in the last build I just installed but the command syntax I cannot find under Browser commands.
geposted Wed 16 Nov 16 @ 8:02 pm
working here in 3517 with the following command on a custom button
browsed_song rating 5
geposted Wed 16 Nov 16 @ 9:14 pm
Take a look here:
http://www.virtualdj.com/products/virtualdj/changelog.html?view=advanced
Changelog EARLY ACCESS
BUILD 3517 (2016-11-14)
-Improve decoding performance of HEVC videos
-Fix video sample showing 1 old frame when retriggering
-browsed_song action to modify fields such as rating from browsed file
-Fix editing of track and video edits
Try something like this on a custom-button:
and things get done ;o)
geposted Wed 16 Nov 16 @ 9:15 pm
Damm. Not fast enough ;o)
geposted Wed 16 Nov 16 @ 9:17 pm
