Forum: Old versions
Topic: VIRTUAL DJ VERSION 8 UPGRADE
Hi, I have a fully paid up virtual DJ cue version 7 licence, i would like to upgrade to version 8 my question is do i need to pay again for a virtual 8 licence or is the upgrade free, If the upgrade is free does anyone have the link i can go to. Thanks in advance.
I have already found the answer to my question........If i go to 'buy' then key in my version 7 licence code in the discount price section it gives me a $200 discount just for future reference.
geposted Fri 11 Nov 16 @ 10:15 pm
just a suggestion (if I were you).
I'd go ahead and pay that $99.00 difference. (who knows it might change later).
You can continue using your setup now and when decided to upgrade to the latest, it's ready for you.
Also you get to play with the latest version and guaranteed you will like it.
You can do all the tweaks and set ups the way you want it before you go live with.
