Can we have a means to change the browser column for the default Virtual DJ skin in the future rather than the normal GREY column? I know there are some optional skins with BLUE bar column but it doesn't carries the many features and functions i enjoy from VDJ default skin, i often find myself returning back to the default skin, the usual GREY doesn't catch most eyes,a BLUE or options to change to any colour BROWSER COLUMN please.
geposted Sat 12 Nov 16 @ 10:32 pm
You mean the highlighting bar? The line that goes across the browser horizontally to show which track is selected?
It's quite simple to modify the skin to add some other colour for that line.
You will need to edit the skin XML file, but it's not complicated to colour just the highlight bar.
geposted Sun 13 Nov 16 @ 10:16 am
Yes exactly the highlight bar that indicates a selected bar. How do I edit is it through Documents -Virtual dj-Skins?
geposted Sun 13 Nov 16 @ 10:42 am
geposted Fri 25 Nov 16 @ 3:43 pm
