Topic: Jog Wheel changes Active Deck
CueItUpPRO InfinityMember since 2014
I'm VDJ 7 I could load a track and it would set that deck as active then I could make the playing deck active (so I could better see the waveform) it would stay as the active deck. I could then use the jog wheel to setup the non playing deck and the playing deck would stay active. In VDJ 8 the playing deck won't stay active. Every time I touch my jog wheel
Or bump my controller, really, it changes the non playing deck to active.
Is there anyway to make that stop? I want the deck I select to be the active deck to stay the active deck no matter what I do.
geposted Sat 19 Nov 16 @ 6:49 am
setting autoHeadphones to either "No" or "OnLoad"
and perhaps you may want to set the setting pflOnselect to No|Yes, if you want the Headphones to follow the deck selection or not.
geposted Sat 19 Nov 16 @ 7:30 am
Thank you!
geposted Sat 19 Nov 16 @ 7:49 am
