Topic: Adding To Virtual Folders - Possible Bug
CueItUpPRO InfinityMember since 2014
When a virtual folder is selected in the folder pane and a search is performed trying to drag/drop a song from the search result into said folder sometimes does not add song to the virtual folder.
For example, I have a Virtual Folder for Requests. I will search for the song, then attempt to drag and drop the chosen song from the search result into the Requests Folder. Sometimes the songs will then appear in the virtual folder, sometimes they won't. I can add the track to the side list or automix, then click the folder and then drag and drop the song from side list or automix into the song list area and it seems to save it, but not when dropping it on the folder in the folder pane.
geposted Sat 19 Nov 16 @ 6:07 pm
I encounter the same problem. You have to let the song hover over the folder for a couple seconds, then it should drop it.
geposted Mon 21 Nov 16 @ 4:31 am
