Discussion about Rate'n'Colour
Rate & Colour is a simple pad page to quickly tag tracks from your pads.
Pick the star rating from param 1 pick browsed or loaded file from param 2 and pick a colour from the pads.
Because there is no direct way to colour a loaded file this employs a work around, getting the loaded track name, searching for it, marking the track and then going back to the previous folder - therefore to mark the loaded track you must have browsed at least one other folder once in the session.
Shift pad 1 removes the colour on the track.
geposted Mon 21 Nov 16 @ 4:04 pm
star rating not being added
n e 1 else getting this????
geposted Thu 24 Nov 16 @ 10:57 am
rating isn't set until you press a pad
Pick the rating, via param 1
choose browsed or loaded from param 2
pick the colour from the pads.
if you don't want a colour use pad 8
geposted Thu 24 Nov 16 @ 11:12 am
Could there be a bug by the pad8: No Colour ? Nothing happens by click!
If i changed it to the following it works!
up 'varDeckBrowser' ? var 'varRating' 0 ? rating 0 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'none' & goto_last_folder & goto_last_folder : var 'varRating' 1 ? rating 1 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'none' & goto_last_folder & goto_last_folder : var 'varRating' 2 ? rating 2 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'none' & goto_last_folder & goto_last_folder : var 'varRating' 3 ? rating 3 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'none' & goto_last_folder & goto_last_folder : var 'varRating' 4 ? rating 4 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'none' & goto_last_folder & goto_last_folder : var 'varRating' 5 ? rating 5 & get_title_remix & param_cast & search & repeat_start 'rsCTFD' 250ms 1 & browsed_file_color 'none' & goto_last_folder & goto_last_folder : nothing : var 'varRating' 0 ? browsed_song rating 0 & browsed_file_color 'none' : var 'varRating' 1 ? browsed_song rating 1 & browsed_file_color 'none' : var 'varRating' 2 ? browsed_song rating 2 & browsed_file_color 'none' : var 'varRating' 3 ? browsed_song rating 3 & browsed_file_color 'none' : var 'varRating' 4 ? browsed_song rating 4 & browsed_file_color 'none' : var 'varRating' 5 ? browsed_song rating 5 & browsed_file_color 'none' : Nothing
i just changed the color from another pad for example from 'green' to 'none'
geposted Thu 08 Nov 18 @ 6:49 pm
