Discussion about Browser Tweaks
Download Link : https://virtualdj.com/files/tools/Browser%20Tweaks.exe
geposted Fri 25 Nov 16 @ 2:49 pm
How you use this program. Im trying to change stufff but I dont know where to open it up at????
geposted Sat 26 Nov 16 @ 2:08 am
The installer unfortunately doesnt create any desktop shortcut, so you will have to open the Browser Tweaks executable from Program Files->Browser Tweaks.
Read more here.. http://www.virtualdj.com/forums/214162/VirtualDJ_Skins/Browser_Tweaks__Skin_Tool_.html
geposted Sat 26 Nov 16 @ 3:12 am
Updated to 1.1
- Added option to change the Browser Fonts (name,size,weight)
geposted Mon 28 Nov 16 @ 3:42 am
DJ Dad Quick Question sir ? after i edit a skin it makes a new skin folder but with (Browser edit) in the name do i have to keep the original skin folder or can i delete it ? just didnt know if i had to keep both lol
geposted Tue 29 Nov 16 @ 3:18 am
No folder is created. Just zip files inside the VirtualDJ/Skins folder.
You can delete the old skinname.zip file and then rename the new skinname (Browser Edit).zip back to skinname.zip
The purpose of creating a skin with a different name, is to keep the original just in case something goes wrong. So after you test the new one and make sure it loads fine (this is good enough to tell that the tool did its job without issues), you can delete the old (original) one.
geposted Wed 30 Nov 16 @ 6:19 am
Thanx sir
geposted Wed 30 Nov 16 @ 2:23 pm
Hello,
Is it possible to have a high dpi version for surface 4 ( same for skin extractor) ?
I try your tools ans they are fantastics
Thanks
Thanks
geposted Fri 02 Dec 16 @ 12:09 pm
Sorry, what is the issue on high dpi ?
geposted Fri 02 Dec 16 @ 5:37 pm
On surface 4 the window program is very small and we don't see all the tabs, the words are cutted. Will try to make a screenshot as soon as possible (I doesn't have the surface with me at the moment)
geposted Sat 03 Dec 16 @ 9:37 am
here's the screenshot
geposted Sat 03 Dec 16 @ 5:40 pm
Hi DjDad,
1.Does this prog work well with the latest Fruit skin 0.82?
2. Would anyone know the exact font / settings that this skin has? So I can use that with the Fruit Skin in the browser. its the MidnightBlueHD skin. I really really like this font, colour and font spacing.
https://www.virtualdj.com/forums/187100/VirtualDJ_Skins/_NEW___VDJ8__MidnightBlueHD.html So this font, colour and spacing but then add it to the Fruit skin with your program. Can you tell me how to do it real quickly?
Much appreciated! Timm
geposted Fri 19 May 17 @ 9:32 am
It's not an one-click job.
- Extract the zip skin file to a folder.
- Open one of the included xml file with a Text/XML Editor (e.g. Notepad++)
- Search for "browser"
- Open Browser Tweaks and select the Fruit skin.
- Manually copy all the the html colors you see in the <browser> elements of the Midnight xml to the html values of the Color Picker in Browser Tweaks for each color.
- for the font, the Midnight skin uses Segoe UI Semibold (you can see that at the top of the xml file). The size is defined in the <font lines of the <browser>
geposted Fri 19 May 17 @ 12:04 pm
Thanks for your reply.. tried it. Doesnt really seem to work. Any chance you can help me out with this one and compile a new Fruit Skin with that font? Just asking :-D
Thanks for replying anyway.
T
T
geposted Wed 24 May 17 @ 12:24 pm
Your issue is probably because the FRUiT skin is pretty complex.
It has multiple <browser> sections because the skin is so customisable that the browsers need to be different sizes when things are added or removed from the view(s).
You should PM FRUiT and ask for his help. He's a pleasant fellow.
geposted Wed 24 May 17 @ 5:23 pm
"pleasant fellow" haha sounds encouraging :)
ok thanks for replying groovindj
T
T
geposted Thu 25 May 17 @ 8:56 am
I did take a quick look at how FRUiT has his skin configured, and it seems to me (at first glance) that he uses just one font throughout, so it would be easy to change - if you were happy with having your font choice in the entire skin (not just the browser parts).
As for the browsers I see three separate <define> areas that you'd need to tweak.
geposted Thu 25 May 17 @ 6:30 pm
Browser Tweaks is updated to version 2.0
Changelog
Changelog
- Ability to include Custom Icons from another skin
- Ability to include floating Windows from another skin
- Ability to change global Font and adjust the overal size
- Ability to adjust the height of the Browser Lines
- Added Plugin GUI Browser Font selection
- Minor fixes
geposted Fri 21 Jul 17 @ 12:33 pm
will there be a MAC browser Tweaks from your Browser Tweaks DjDad
geposted Fri 21 Jul 17 @ 1:17 pm
Browser Tweaks is updated to version 3
Changelog
Changelog
- Added new Browser tabs to tweak the FX GUI, Search and Prelisten
- Added new option for White Icons (for White Browsers)
- Added Browser Preview
- Black & White themes
- Added Custom Profile management (load/save/delete)
- Default and White Browser Profiles included
- Added Tooltips (and option to disable)
- Theme and Tooltips settings saved
- About Help window to check for updates and Browser Tweaks forums
- Minor fixes
- Possible High-DPI fix
geposted Thu 03 Aug 17 @ 2:54 pm
