Discussion about Skin Builder
geposted Fri 25 Nov 16 @ 3:11 pm
Can you start with the default skin with this and then just make small changes, or do you start with a blank page so to speak? I use the default skin, and dont want to detract from that too much, but would just like to add in a row of knobs that i can set as the volume for each sample group. I have already added in the custom buttons.
geposted Fri 25 Nov 16 @ 3:15 pm
you start from scratch andy,
OT but if you've added custom buttons you can add custom dials in just the same way and map map them to your sampler groups
geposted Fri 25 Nov 16 @ 3:43 pm
Yeah i added the custom butons x 3 and custom dial x1 each deck, this was just an option to tick in the settings menu. Are you saying there is more? The reason i want this, and maybe there is another way round this, is that I use apc mini for samples. But unlike my controller, VDJ doesn't remember the fader position. so being able to see each fader and what position it is at would be nice, though it would just be better if VDJ remembered the fader position. I have the one custom dial set as the sample master volume.
geposted Fri 25 Nov 16 @ 3:50 pm
we'll take this to pm
geposted Fri 25 Nov 16 @ 3:59 pm
Off topic post, self censored. :-)
geposted Fri 25 Nov 16 @ 5:52 pm
Can You make a Video on this NEW V3 ?
geposted Fri 25 Nov 16 @ 8:34 pm
doesn´t run on mac :(
geposted Fri 25 Nov 16 @ 9:58 pm
Ok i bilt my skin, but because of certain features, i still use silver sleek 3. My question is How can i use different things instead of what included in the builder. Like I want the bar counter in my rhythm wave. Is that possible?
geposted Sun 18 Dec 16 @ 1:17 pm
Working with JMF to add things to my skin, what you guys think. Its a controller external mixer type skin.
geposted Mon 19 Dec 16 @ 8:08 pm
Skin Builder v3 need work for mac user ALL the icons are took small to use or see and when you try to move or resize they disappear.
https://youtu.be/ShIwFkum3cI
geposted Mon 19 Dec 16 @ 8:29 pm
We just incorporated Phantomdj's preparation skin ooooh...we having fun
geposted Mon 19 Dec 16 @ 9:56 pm
