Topic: skin blinking flickering ..help
So i i have been noticing while djin that my vdj blinks randomly ..not bad tho but noticable..at first i thought i was seeing things lol
Mbp dual core running osx 10.10
A friend of mines is also having this problem but his is worse ..you cant see anything but the decks and when it shows sign in window its either chinese letters or unledgable
Doesnt happen with any other program on the cpu which osx17 inch mbp dual core osx 10.7.5
since mine does it soo random its hard to catch it on video but here is a vid of my friends cause thats all it does ..its unusable
https://youtu.be/OODAsgtkInc
geposted Mon 28 Nov 16 @ 4:21 pm
also should mention that we came to the website and downloaded the trial to try on the cpu(i didnt wanna put my log in info on his computer)
also , i went to skins folder and the only folder showing is a iphone folder but its empty too ..is this normal? should i try and install by loggin into my account for him since he was tryin to let me use it for a backup incase mines act wierd again
Thank You
Hi DJ T boogie,
Did you manage to solve your problem as I have exactly the same issue...skin blinking and flashing...completely unstable! It started with the OS Sierra update!
I have reinstalled VDJ 3 times without any success...definitely need help!
Not as of yet..but its 2 different macbooks one in video wont even load correct with default skin and demo version
Gig computer does it when it wants at first i thought my eyes were decieving me but then i realised it was just ramdomly blinking ..thats what made me try the other for a backup but thts not happening
And unless the reccomened specs arw not updated on vdj page thwn i should have more that enough to run properly
Its does say that it compatible wit sierra but my gig computer is running yosemite and the other one is still on mavericks
