Topic: Left and Right levels
I need a script to reduce the left level and increase the right level simultaneously
geposted Wed 30 Nov 16 @ 7:37 pm
Disregard the Addon.
For Keyboard you need something like...
deck left volume -5% & deck right volume +5%
and
deck left volume +5% & deck right volume -5%
you can change the x% for faster or slower movements.
Is there anyway to make vdj output audio in mono?
There's an addon, sbdj stereo , I think that's what it's called
Cheers!
Thank you DJ5826. Is there a way to automate it, instead of having to press the button so many times?
if you are using just 2 decks, why dont you use the crossfader ?
you can map a button to automatically fade from one side to the other..
auto_crossfade 2000ms (change the 2000 to a larger value t get a smoother crossfade.)
