Topic: FX setting display
ThelemaPRO InfinityMember since 2010
Hello.
Every time I open VDJ and plan a new set to record, I have to open each of the effects' setting display window individually. Is there a way to keep them open? I'm currently using the Numark Mixtrack Pro 2 skin, and it's a pain in the ass to keep opening at least 6 different effect setting windows every time I open VDJ.
geposted Sun 04 Dec 16 @ 1:22 am
deck X effect_show_gui "effectName" & deck X effect_show_gui "nextEffectName"
geposted Sun 04 Dec 16 @ 10:22 am
lincol2PRO InfinityMember since 2011
What is the script to close it in the display window now that it is open ?
geposted Sun 04 Dec 16 @ 1:38 pm
the same, without a on/off or 1/0 param at the end the script works as a toggle.
geposted Sun 04 Dec 16 @ 3:42 pm
thx locodog
geposted Sun 04 Dec 16 @ 4:55 pm
