Topic: Trouble with Mixing - Virtual DJ 8
Hello community
I have just got virtual DJ 8 and while mixing Ive tried to listen to Deck A while Deck B is playing so I can mix Deck A into Deck B but its not allowing me to listen to Deck A unless I put the cross fader in the middle or to Deck A's side. I should be able to hear Deck A while mixing it into Deck B with out playing out loud but its not allowing me to hear it so I can mix it in.
Can someone please direct me in how to fix this as I never had this problem with the previous Virtual DJ
Thanks
geposted Tue 06 Dec 16 @ 10:49 pm
Your sound config will help here,
but check headphone mix [master panel]
