Topic: Ddj SZ Issues
Overall my SZ is great I have had it for about 2 years and has always had these 2 issues that I can't figure out. First for the majortity but not all the time when I load the same track on different decks, the jog wheel marker for each deck will be at different locations on the first beat ie. deck 1 at 12 o'clock and deck 2 at 4 o'clock. It happens regardless if I have a cue point set or not. If a cue is set it will go to the cue point but the jog wheels won't be in synchronization which sucks when I beat juggle. The second issue is with the Stop Time knobs. Say if I just powered my SZ on, opened VDJ and I've been playing for 10 seconds or 6 hours. Decks 1&2 will stop wherever the Stop Time knob is set for, but 3&4 will not. No mater how long i have been playing for 3&4 will not stop where the knob is until I adjust the knob just a fraction of a hair and then its fine. But when I restart VDJ I have to go thru the process all over again. Has anyone else experienced this or can help me out? Thanks.
geposted Wed 07 Dec 16 @ 3:37 am
1. The white markers on the jogs represent the "vinyl" mark on the track. Unless you change the "RPM" option from 33 (rounds per minute) to 4 beats they are never supposed to be in sync
2. Change the mapping of <STOP_TIME> key to:
device_side 'left' ? deck 1 brakespeed & deck 3 brakespeed : deck 2 brakespeed & deck 4 brakespeed
Thanks that worked for the break speed but i think the problem with the marker was I had the AutoDiskMarker on. All seems to be working as i wanted now thanks.
