Topic: HID supported controllers
are there any HID controllers(not players) out there currently supported(natively or otherwise) with vdj 8???
geposted Thu 08 Dec 16 @ 2:13 am
Gemini G2V
Gemini G4V
Hercules JogVision
Kontrol S2 MK2
Kontrol S4 MK2
Pioneer XDJ-Aero
Pioneer XDJ-R1
Pioneer DDJ-RZ
Those are just a few that come up my mind.
However you should go the other way around: Find the HID controller you want and then check if it's supported. Most likely it is! :)
so i take it that vdj 8 will take advantage of the faster HID protocol instead or the normal midi on these controllers?
