Forum: VirtualDJ Skins
Topic: Battery Status Indicator
Is there any way I can display the battery level on my VDJ skin? The only discussion about this seems to be a few years old: http://www.virtualdj.com/forums/179500/Wishes_and_new_features/Battery_Status.html
The plugin mentioned within that discussion doesn't work for Mac. Has nothing been done about displaying battery level since then?! Seems improbable. Can someone please point me in the right direction? Thanks :)
geposted Thu 08 Dec 16 @ 8:13 pm
geposted Thu 08 Dec 16 @ 9:16 pm
Doesnt directly answer my question, but thank you so much for pointing me to the skin. Its quite the piece of amazing work!! I will be able to look into the xml and use it to display battery on my own custom skin. Problem solved :)
EDIT: Here's the funny thing. 'is_battery?' works on windows, but doesn't seem to work on Mac OS :( . Any workarounds?
geposted Sat 10 Dec 16 @ 4:07 pm
Yes, doesnt work on Mac atm. Reported and will be fixed soon.
geposted Sun 11 Dec 16 @ 1:12 pm
Cool. Will wait for the next app update :) Thanks! :)
geposted Mon 12 Dec 16 @ 7:48 pm
Can the battery indicator work on the Android Remote App??
geposted Sun 25 Dec 16 @ 5:07 pm
