I am building a custom skin, and I want to check and display if my laptop is connected to external power. Accordingly I am using "is_battery" to toggle visibility of the element on my skin. This works fine for me on Windows. However it doesnt seem to work on Mac. Is this a known issue with a workaround? Do I need to query a different variable on Mac?
'get_battery' seems to work fine on both Windows and Mac, by the way.
Thanks,
Av
Thanks,
Av
geposted Sat 10 Dec 16 @ 4:42 pm
You have posted here as well http://www.virtualdj.com/forums/214464/VirtualDJ_Skins/Battery_Status_Indicator.html and already got a reply.
Closing this as duplicate.
geposted Sun 11 Dec 16 @ 1:27 pm
