Topic: VDJ7-Mixtrack-DJIO-Yamaha amp- music sync issue
I honestly don't know where to post this.....The issue I am having is that when I play a song the speakers and headphones do not match! I've never ran across this ever before and it's impossible to mix anything as when I get it lined up by ear, I can see in the software that the beats are off and when I fade to the speakers the 2 songs are in fact off.
I also downloaded the demo of VDJ8 and have the same issue. I'm leaning towards the amp creating the delay, is that a possibility? I don't have anything else to test with. This amp also has bluetooth, so I connected that way and had the same delay. Either way, why is there nothing in the VDJ settings to accommodate for this? Or is there?
Any help is appreciated.
geposted Sun 11 Dec 16 @ 6:08 am
Okay, it's the amp. Plugged into a little bluetooth speaker and it's synced fine. Any ideas on how to dj through this Yamaha amp? It's a RX-V379, which is a newer model and should work or have the ability to work?
