Topic: Video override
I tired out the over_video command this weekend and not sure if I'm missing something. I set a button as "over_video 1" and another as "over_video 2". When I selected either, the video output would be the selected deck, however it remained on that output. I assumed I could toggle back and forth between video outputs, but I was not able to.
How do I cancel the video output override? Hitting it again didn't work. Is there another command to cancel the override?
geposted Mon 12 Dec 16 @ 7:21 pm
Instead of 'over_video 1' and 'over_video 2' use 'deck 1 over_video' and 'deck 2 over_video'
I'll give that a shot. Cheers
That does work to toggle between video sources. thanks.
Is there a way to disengage the override and go back to having the crossfader control the output?
The buttons will toggle on/off too.
I thought I tried that, I guess not...
thanks Scott!
