Forum: Wishes and new features
Topic: Automix editor
Is it possible to make it so that we can control the levels of each deck throughout the auto mix, or at least the position of the fader instead of it just being a smooth fade? Is it possible to make a volume or fader envelope to save the auto mix levels of each deck so that if we wanted to keep each track at max volume through the beat mix, then suddenly cut it at a point instead of a gradual fade?
Edit: moderator: if you can please update the title of this message to add and specify the feature of the auto mix editor function asked about. i.e.: auto mix editor: Customize fader/level of both decks throughout the length of the transition
I forgot to specify before I hit post
-thanks
chris
geposted Fri 16 Dec 16 @ 11:12 am
