Hi. Everywhere it says Twitch and VDJ are supported but the mapping is virtually non existent. I don't understand exactly what is natively supported. None of the pads work properly for Hot Cue, Slicer, Loops. Effects all over the place. Most things are not working. So at what point do they consider something mapped?? Anyone else stuck with this? Have I done something wrong?
For example:
Currenly VDJ8.2 native mapping to Novation Twitch controller:
PAD1 = var 'mode' 1 ? var 'shift' ? deck active sampler 1 rec & sampler 1 select : sampler 1 play_stop & sampler 1 select : var 'mode' 2 ? loop 0.125 : var 'mode' 3 ? loop 0.125 while_pressed : var 'shift' ? delete_cue 1 : hot_cue 1
But Twitch does not have a sampler. Mode 0 should be hot cues, mode 1 should be slicer. mode 2 auto loop, mode 3 loop roll. The mapping also shows mode 2 and mode 3 as the same loop function, but I think mode 3 should be loop_roll or something..?
For example:
geposted Fri 16 Dec 16 @ 9:20 pm
It is calling v8's sampler
Honestly I don't get the mapping myself, Looks like it hasn't be updated for pads...
geposted Fri 16 Dec 16 @ 10:16 pm
Not sure but I found this-
https://maps.djtechtools.com/mappings/5135
FYI definitely interested to see how this works - let me know.
looking at Virtual DJ but I wish there was a way to test out my Twitch 1st. Since I see issues here in the forum.
geposted Thu 03 Jan 19 @ 4:47 pm
You can test out your Twitch with VDJ - it's natively supported. It will work for 10 mins at a time.
geposted Thu 03 Jan 19 @ 5:52 pm
thanks = will test VDJ tonight...
geposted Fri 04 Jan 19 @ 3:19 pm
so yeah it work is working well = except I couldn't get my headphone cue to work? the knob works scrolling towards the master but still no sound on cue. I tried various combination recommended.
using the twitch soundcard
Master
channel 1 + 2
Headphones
channel 3 + 4
id there something im missing...
So far i am liking the speedy start up and the sound quality in general.
Master
channel 1 + 2
Headphones
channel 3 + 4
geposted Sat 05 Jan 19 @ 2:10 am
where could I find the mapping for novation twitch for vdj8
geposted Thu 30 May 19 @ 4:28 pm
In the program. It's built in. Plug the Twitch in and VDJ should detect it.
geposted Thu 30 May 19 @ 4:30 pm
