Topic: Build 3543 database value not increasing
I'm using build 3543 and I've noticed that the database value that is stored in the virtual dj folder on my hard drive isn't increasing in value. Usually when I add more songs to the database the size (in kb) will increase, but for the past few weeks this is not happening. However all the new songs, tag edits, cue points and any other modifications are stored successfully in the database. I'm wondering if this is a bug with b3543 as I know it was withdrawn not long after it was released.
geposted Sun 18 Dec 16 @ 1:34 pm
As long as all your edits are saved all is good.
If you delete songs and clean the database, the space in the database gets emptied, and so there's more room to store new tags without increasing the size.
