Discussion about New PC-Optimizer
geposted Mon 19 Dec 16 @ 9:23 am
Based on SAM's PC-Optimizer.
RED = Service or Program found AND running
DarkGreen = Service or Program found but NOT Running
LightGreen = Service or Program NOT found
You can add or remove Entrys, based on your Software-Environment
Adding by clicking on "New Entry", Removing by marking the row end press "Del".
You are able to save different config-Files, based on your needs (e.g. with or whitout Internet, music only or music/video)
Try disabling all first and if all is fine save your config. If somithing went's wrong e.g playing videos, enable one by one and test it.
geposted Mon 19 Dec 16 @ 11:27 am
Starts in German: how do you change the language ???
geposted Mon 19 Dec 16 @ 11:44 am
Should start based on your os-language (German, Frech, English). If it doesn't do that i will recompile it, but not until 28/29.12.16, sorry
geposted Mon 19 Dec 16 @ 11:53 am
Updated Version online. Changes in language-detection.
geposted Sat 24 Dec 16 @ 6:46 am
Hi. I have downloaded the Addon, but I cannot install it. I unpack the data but the .EXE file is not working. Can anyone give me a short feedback how this addon must be installed? Thank you
geposted Wed 28 Dec 16 @ 9:22 pm
There is no installer. You just have to unzip it to a place you like. Please notice: If you have disabled the extensions in windows explorer you willl see a .exe that is not the real executable. It is the config file. Just start the "VDJ-PCOptimizer"-file. (You must have .Net-Framework 4.5.2 or above installed first)
geposted Thu 29 Dec 16 @ 8:03 am
2 PC with Windows 7x64 crash on launch
Firma problema:
Nome evento problema: CLR20r3
Firma problema 01: VDJ-PCOptimizer.exe
Firma problema 02: 1.0.0.1
Firma problema 03: 5858dd11
Firma problema 04: mscorlib
Firma problema 05: 4.6.1590.0
Firma problema 06: 5787ed44
Firma problema 07: 2c0d
Firma problema 08: 50
Firma problema 09: KUTS43RW3WMPE3EWT1R1Z5M5MTM1NR04
Versione SO: 6.1.7601.2.1.0.256.1
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 0a9e
Ulteriori informazioni 2: 0a9e372d3b4ad19135b953a78882e789
Ulteriori informazioni 3: 0a9e
Ulteriori informazioni 4: 0a9e372d3b4ad19135b953a78882e789
Firma problema:
geposted Sat 31 Dec 16 @ 11:17 am
Firma problema:
Firma problema:
2 Questions: First, the Version 1.0 was functional?
Second: Do you have had .Net-framework 4.5.2 or above installed and also enabled?
geposted Sat 31 Dec 16 @ 11:29 am
First, the Version 1.0 was functional? YES
Second: Do you have had .Net-framework 4.5.2 or above installed and also enabled? YES
geposted Sat 31 Dec 16 @ 11:46 am
Please send me a PM with your email. I will send you a spanish localized VDJ-PCOptimizer.exe as a zip. It's automatic translated and i think it will be as horrible as the microsoft german translations.
geposted Sat 31 Dec 16 @ 11:50 am
Not loading in English
geposted Sat 31 Dec 16 @ 5:13 pm
New PC-Optimizer nao esta funcionando,tenho windows 7 Ultimate Sp1 e frame work 4.6.2 mas eu executo e nada funciona,uma luz por favor,obrigado.
geposted Mon 02 Jan 17 @ 4:03 am
HELP...
Installed " Microsoft .NET Framework 4.6.2 ", Unzipped VDJ-PCOptimizer. Tried running "VDJ-PCOptimizer" Application, then tried running "VDJ-PCOptimizer.exe.config"
Nothing happens. Can someone please tell me what I am doing wrong?
geposted Sun 08 Jan 17 @ 3:19 pm
djbill359 wrote :
HELP...
Please tell me, what Kind of OS, which language.
geposted Mon 09 Jan 17 @ 9:45 am
Windows 8.1 (English)
geposted Tue 10 Jan 17 @ 11:58 pm
Please take a look into your unzipped folder: there should be these files and directorys. Is anyone missing?
<DIR> en
<DIR> fr
CustomData.xml
Daten.xml
Infragistics4.Documents.Core.v16.2.dll
Infragistics4.Documents.Core.v16.2.xml
Infragistics4.Documents.Excel.v16.2.dll
Infragistics4.Documents.Excel.v16.2.xml
Infragistics4.Shared.v16.2.dll
Infragistics4.Shared.v16.2.xml
Infragistics4.Win.Misc.v16.2.dll
Infragistics4.Win.Misc.v16.2.xml
Infragistics4.Win.UltraWinDataSource.v16.2.dll
Infragistics4.Win.UltraWinDataSource.v16.2.xml
Infragistics4.Win.UltraWinGrid.ExcelExport.v16.2.dll
Infragistics4.Win.UltraWinGrid.ExcelExport.v16.2.xml
Infragistics4.Win.UltraWinGrid.v16.2.dll
Infragistics4.Win.UltraWinGrid.v16.2.xml
Infragistics4.Win.UltraWinListView.v16.2.dll
Infragistics4.Win.UltraWinListView.v16.2.xml
Infragistics4.Win.v16.2.dll
Infragistics4.Win.v16.2.xml
VDJ-PCOptimizer.exe
Also: on some OS's there will be a Warning on the first start (e.g. for smart-screen-filter etc.), cause these files are not very popular to the world. You have to accept running them. I send them always to symantec for whitelisting them, but if you use another Anti-Virus-software you have to try to disable it or manually create an exception for your special software product.
Try following:
1. Restart your computer and do not open any program
2. doubleclick "VDJ-PCOptimizer.exe"
3. Take a look at your taskmanager if it is running
Further Info's: the program has to start with administrative rights. Normaly it should ask you on startup, but if that will not happen, do it by right click and choose "start as administrator"; Possibly it helps.
I will install a original 8.1 in english on a test machine and will take a look, but that needs a few days for me.
<DIR> en
<DIR> fr
CustomData.xml
Daten.xml
VDJ-PCOptimizer.exe
Try following:
geposted Wed 11 Jan 17 @ 7:32 am
Downloaded this to try it, extracted, ran the application file, nothing happened.
wat do?
wat do?
geposted Tue 17 Jan 17 @ 10:42 am
wat do?
wat do?
What kind of os, language, installed .Net-Framework?
Did you compare the file-list above?
Did you run it as administrator?
geposted Tue 17 Jan 17 @ 12:22 pm
wat do?
wat do?
win 8.1, english, 4.6.2 net framework installed, every files is in it, yes i ran as administrator both by right click option and by confirming the warning box when just double clicking the application file
''Try following:
3. Take a look at your taskmanager if it is running''
This didnt help, the application did not show in task manager
geposted Wed 18 Jan 17 @ 11:21 am
