Topic: Extreme Cut Video Transition Problem
I would like to report a bug according the Extreme Cut Plug in.
I have a playlist in automix playing with the option "random video transition". When this plugin is selected for the next transition the video becomes laggy and greeny. This stays so until I disable the video and re-enable it.
I tried to move it to ignore folder but every time I restart Vdj it comes back out of the folder. Tried already uninstalling Vdj, deleting the VirtualDJ folder from "my documents", re-install it with default settings without any luck.
Thank you for your time and I wish you happy holidays!
geposted Fri 23 Dec 16 @ 11:19 pm
