Topic: VDJ EQ Settings
Hello,
Have any of you touched the eq settings in config? If so, what have you tweaked the settings to?
Thanks!
geposted Thu 19 Jan 17 @ 9:53 pm
On the same subject.
With EQ default settings 200,1700, 6500 is this settings genre specific? Or asked in another way is this settings suited for both 'Asian music" and Reggaeton music? If not what are possible suitable settings you have used for different genres?
As a mobile DJ, I play a wide variety of music from the 40s, 50s, disco, rock, Top 40, etc, so it is not just one kind.
I think I reduced the LOW to something like 150 or 120.
