I'd like to turn a custom button on a SKIN (SliverSleek) into a "Shift" button that toggles.
I can get the button to shift but I can't figure out the toggle part.
Any help would be great appreciated.
geposted Wed 25 Jan 17 @ 12:06 am
1,2 or 3?
Not sure you can, let's rethink, why do you want a latching shift, what will you be doing?
geposted Wed 25 Jan 17 @ 1:31 am
I dont think the shift action can work as "toggle".
Not sure why such a button is required, but keep in mind that the actions assigned to SHIFT+PAD can be performed with mouse right-click from a skin.
geposted Wed 25 Jan 17 @ 1:43 am
Well sometimes when I'm prepping tracks I need the loop back and on SliverSleek I have to shift to get it to show on the pads.
Plus I like to delete remix points and loops.
Basically I'm only using 1 deck and that's it, unless I wanna mix a new track to see how it sounds. But mostly using 1 deck.
And I don't use a mouse.
I'm posted up in my recliner with just some headphones and my laptop.....
geposted Wed 25 Jan 17 @ 1:53 am
assign "shift" to a keyboard key.
geposted Wed 25 Jan 17 @ 2:36 am
But then I have to set my beer down and use 2 hands, lmmfao!!
Well I guess it can't be done......bummer.
geposted Wed 25 Jan 17 @ 3:00 am
down ? toggle 'toggleShift' & var_equal 'toggleShift' 1 ? shift on : shift off
geposted Wed 25 Jan 17 @ 7:24 am
PERFECT!!
Thanks a million!!
Thanks a million!!
geposted Wed 25 Jan 17 @ 12:39 pm
