hello
I have modified a skin to suit my need : I want the pitch go fast when push to top and slow to bottom. So, I code the pitch to direction up, and it's working; but of course it didn'match the direction of my hardware controller so I map the pitch with 'param_invert & pitch' and it works : same direction of the slider on the skin and my controller. But and this is the problem : I have the arrows to show you how to move you're hardware pitch to match the one on the skin and as soon as I move the hardware pitch, the slider on the skin jump quickly to the other side (he jump to catch the 'phantom' fader). this not happen if I don't use param_invert. I've try it with other skin (multi fx, swap BGL) and it's the same. bug ?
sorry for long post trying to explain my best.
thanks
thanks
geposted Fri 27 Jan 17 @ 3:59 pm
I see the issue. We ll investigate and let u know.
geposted Fri 27 Jan 17 @ 4:28 pm
Hello,
Any news on this ?
Thanks
Any news on this ?
Thanks
geposted Sun 26 Feb 17 @ 4:38 am
Is this still in investigation ?
geposted Mon 06 Mar 17 @ 7:56 pm
Its been reported but no fix so far.
geposted Tue 07 Mar 17 @ 12:42 pm
OK thanks
geposted Tue 07 Mar 17 @ 2:58 pm
