Topic: 99 Cue Points
geposted Sun 29 Jan 17 @ 7:34 pm
For v8 I have found this to be false,
Routine makes use of 6400 hotcues although the maximum it will use at one time is a mere 800
Thank you for the Reply.
What Routine are you talking about? (Sorry, Newbie here)
Routine is a plugin I wrote that records and replays cue juggling routines, like serato's flip
Only mine does 2 more and is editable
(I need to get working on the new xml version)
It's for pro licence users only and it will be like that until I get it reading/writing an xml and released on mac
Thanks again.
I think for my humble purposes it's good enough to know that 99 CUE points is not all I can save. With hundreds of songs in a library, that would be ridiculous.
Lol, no, the old 99 cue limit was PER track, not across the entire database.
I was talking about per track as well.
I can still hear you laughing... *facepalm*
Well, at least that's solved :D
The current numerical limit in VDJ 8 is just over 2 billion cue points per song (2147483647).
[BillGates]More than anyone will ever need.[/BillGates]
