Does anyone know if you can makes a spinning circular graphic appear to speed up as the song progresses?
geposted Mon 30 Jan 17 @ 9:14 pm
Depends on how you define "appears as speed up" but yes it's possible.
A quick way of doing it is to multiply the source of your visual
As a draft example: source="param_bigger 75% song_pos ? get_rotation & param_multiply 4 : param_bigger 50% song_pos ? get_rotation & param_multiply 2 : get_rotation"
Of course you'll need to adjust it on your personal needs
geposted Mon 30 Jan 17 @ 10:54 pm
I'll play around with that! thanks!
geposted Tue 31 Jan 17 @ 12:00 am
