Ive been away from my setup for a little while and of course I chose to "upgrade to the newest version" when I got the notification window, which I usually regret doing. Well.. now Ive got erratic BPM AND I can beat mix both channels on point and the BPM displays are not the same. Example...left side will be displaying 135 and the right side will be displaying 143 and yet they are perfectly matched. Getting tired of the constant issues with this program or the endless bugs that have to be ironed out just to get a decent play. Another issue is You can watch one channel or the other BPM increase and decrease by itslef. Jumps up and down 1 to 3 beats at times. Other than trying to unistall and reinstalling is there any easy fixes for this?
vinyl timecode w/ an AA14MXR
geposted Tue 31 Jan 17 @ 1:56 am
Same problem here. bpms don't match. additionaly, timecode seems to fluctuate in the setup screen. I can match beats and then song starts to drift a bit...
geposted Fri 24 Feb 17 @ 5:01 am
