I know i can make things happen based on certain things, Like Visibility="not_loaded", but i can't find a list of the things i can query, like how do i set visibility based on if the deck is playing or stopped? Or Paused, as opposed to stopped... etc...
geposted Wed 01 Feb 17 @ 12:35 am
"playing ? parameter 1:parameter 2"
not sure if you have looked at this stuff but it may help -> http://www.virtualdj.com/wiki/VDJ8script.html
there is a list of verbs then examples at the bottom
geposted Wed 01 Feb 17 @ 1:08 am
well, sure, I have... but there is no verb "Playing" listed there...
In fact, "visibility" is not listed either....
geposted Wed 01 Feb 17 @ 1:35 am
Play is the verb any verb that can be queried (returns true or false) can be used, I believe querying sliders gives transparency based on the slider value
Visibility is a skin condition based on the verb queried.
geposted Wed 01 Feb 17 @ 3:31 am
and where can I read more about that? a text search of the VDJ wiki produced very little results for the text "visibility"....
EDIT: Ok, i found a bit, still no list of what i can pass to it... I'd like to have something visible when song_pos = 0, but otherwise not visible.
geposted Wed 01 Feb 17 @ 3:33 am
read the skin wiki, dissect other skins
visibility="song_pos 0"
geposted Wed 01 Feb 17 @ 4:19 am
Aha... I tried "song_pos = 0"...
Been reading the wiki since i posted...
geposted Wed 01 Feb 17 @ 4:20 am
one more then, if you don't mind, i can't find anything about reversing the rotation direction of a spinning graphic...
Also, it's difficult to find skins that do what i want them to do, makes it hard to find examples...
geposted Wed 01 Feb 17 @ 4:22 am
I believe...., but skinning isn't my thing
get_rotation & param_invert
best explain what you are wanting
geposted Wed 01 Feb 17 @ 4:30 am
Thank you for your help, that worked. but song_pos 0 did not. thats ok tho, i'll get it eventually. sorry to be a bother!
geposted Wed 01 Feb 17 @ 4:34 am
Ha Ha! song_pos = 0 makes the graphic fade in as the song progresses!!!
That will be handy to know for the future!
geposted Wed 01 Feb 17 @ 4:46 am
it won't be
song_pos = 0
what vdj will see is
song_pos
which will return a value from 0% to 100%
try
song_pos 0 ? on : off
song_pos = 0
song_pos
try
geposted Wed 01 Feb 17 @ 4:52 am
my mistake, i typed it wrong... "song_pos 0" makes it fade in. i failed to notice my mistake in the post, sorry
geposted Wed 01 Feb 17 @ 4:54 am
