hellp!
How to define font, who not installed in system?
geposted Thu 02 Feb 17 @ 1:24 pm
You can define any font (even if it's not installed) but VirtualDj won't use it because it can't find it.
You'll have to install the font manually
Some skins (like SilverSleek series) offer the required LCD font inside the skin zip file, so that you can extract it and install it on your system
geposted Thu 02 Feb 17 @ 2:28 pm
geposted Thu 02 Feb 17 @ 3:01 pm
