Hi, I'm pretty new to the program so this might be obvious but I'm having some issues figuring out how to release a loop with the Esc key on the correct deck. For example, i'll want to release a loop on Track 1 as i fade it in but it sets a new loop on Track 2 instead, even though i haven't touched the loop function there. Clicking on the Deck i want to control doesn't help and it doesn't matter which deck i set a loop on last, it's just stuck on Deck 2. Halp!
geposted Sun 12 Feb 17 @ 5:45 pm
geposted Sun 12 Feb 17 @ 6:13 pm
wickedmix wrote :
http://www.virtualdj.com/manuals/virtualdj8/interface/decks/decksadvanced/loops/index.html
Maybe I didn't explain the issue well enough cause this doesn't address it. How do you select which deck is active when using keyboard shortcuts?
geposted Sun 12 Feb 17 @ 6:35 pm
Tab
geposted Sun 12 Feb 17 @ 7:02 pm
locodog wrote :
Tab
Bingo! Thanks!
geposted Sun 12 Feb 17 @ 7:23 pm
