Discussion about PlaylistFixer 8
    geposted Mon 20 Feb 17 @ 6:25 pm
          Description is incomplete. Is this only for windows or a mac version is coming soon?
    geposted Tue 21 Feb 17 @ 3:24 am
          This program is Windows only.
I don't have the equipment to write MAC programms, sorry.
EDIT: The description got cut of, so here is the full description:
PlaylistFixer 8 is fixing your playlists and history files after you moved some files and VirtualDJ can't find them anymore. It is basically using the filename to find the file, but if it findes more than one file with the same name, it takes the one with the higher play count.
Please note: If you renamed your files the PlaylistFixer is not able to find them.
geposted Tue 21 Feb 17 @ 7:19 am
          Hello PatchN,
It doesn't open on my PC (windows10)
geposted Tue 21 Feb 17 @ 6:02 pm
          What do you mean?
Does is not open at all or open and close very quickly?
It is meant to open and run in a console window. So no grafical user interface.
geposted Wed 22 Feb 17 @ 10:38 am
          It doesn't open at all
    geposted Wed 22 Feb 17 @ 10:47 am
          Strange and I can't reproduce it.
Does it show up in the taskmanager?
geposted Thu 23 Feb 17 @ 2:15 pm
          It was a windows problem.
All is fine now
    All is fine now
geposted Wed 01 Mar 17 @ 2:48 pm
          can i uninstall this tool?
    geposted Mon 06 Mar 17 @ 8:45 am
          Sure. Just delete the PlaylistFixer8.exe.
There are no other connections or dependecies.
geposted Mon 06 Mar 17 @ 9:06 am
          Could the option be added to rebuild virtual folders (The red folders)
as i move files around my system, it seems any files i add to a virtual folder just disappear
geposted Sun 19 Mar 17 @ 3:58 pm
          In theory, yes, it is possible.
But if VDJ does not update the vFolders if you move the files via VDJ browser, then I consider this a bug and should be reported.
geposted Mon 20 Mar 17 @ 8:30 am
          Hi, I'm having trouble installing this. I can't seem to find the Mac version to download. Any suggestions?
    geposted Sun 21 May 17 @ 3:49 pm
          There is no Mac version I'm afraid.
Sorry
    Sorry
geposted Sun 21 May 17 @ 4:17 pm
          How does this work? all mine says is cannot find file. am i supposed to put the EXE in a specific folder?
    geposted Sat 08 Jul 17 @ 2:47 am
          my norton antivirus removed the file it said it was not safe
    geposted Tue 09 Jan 18 @ 1:22 am
          It is 100% safe and it was checked by VDJ staff.
It is just a false positive.
geposted Tue 09 Jan 18 @ 8:10 am
          it does not work. My files still don't show up.
    geposted Wed 21 Feb 18 @ 5:48 pm
          What does the output in the console window say?
    geposted Mon 26 Feb 18 @ 8:48 am
           Nice, thank you!
The batch process that VDJ has been missing, cumbersome to locate a track one at a time. Traktor had similar ages ago as I remember.
Playlist Fixer is currently mending my history playlists from 2014. :))
geposted Mon 26 Feb 18 @ 2:17 pm
