Forum: Wishes and new features
Topic: touchwheel options as per deck
it would be beneficial to those who use 1 deck for scratching while mixing if the 'touchwheelbackspin' and 'touchwheelforwardspin' options could be applied to per deck(like master tempo in the options menu with the 4 boxes). so as we could apply backspins and forward spins on a deck easily while having a quick release with these settings off on another deck.
geposted Tue 21 Feb 17 @ 9:58 pm
Use a custom button...
ya ...works well...but still not per deck...even if i use a custom button on the left deck side...it changes the option on both decks...and adding deck 1 to the setting script doesnt change anything...still applies to both decks
Explain more, is it something like you only scratch with the left deck or something?
Only scratch with right deck...so i only require to make backspins on the left...but i have used the custom button...although it impacts both decks...i shall get accustomed...thanks bro anyway
Yep that is scriptable, I'll get back to you when sober.
sober yet?
