Hi, I recently downloaded virtual Dj's latest update and when I click on any buttons under the options menu at the top it does not work and just puts like a blue border around the button, any help?
geposted Thu 02 Mar 17 @ 11:10 pm
Did you then click apply? I can only assume you are referring to the audio config buttons?
geposted Thu 02 Mar 17 @ 11:14 pm
Yeah I have but it's just doing the same to the apply button adwell, not causing too much bother but just want to start recording some mixes
geposted Fri 03 Mar 17 @ 12:19 pm
Might be an idea to post a screen shot of what you mean. You can map a key on your keyboard to open the record tab, start a recording, stop a recording etc.
geposted Fri 03 Mar 17 @ 12:28 pm
