Topic: All MP3 Music Missing
My system is running VDJ 8.2 and all of my music mp3 files are missing in my library. All of my history, playlists, directory folders and search and recurse show no music. I go to ITunes and it works fine and all my music is there. I have not changed directories or file locations. I do a recurse and no songs show. I need help!!!
geposted Sun 05 Mar 17 @ 1:06 am
One additional note.. I open my VDJ 7 and everything works there just fine. Is there a separate database that may be corrupted in my vdj 8?
geposted Sun 05 Mar 17 @ 1:29 am
Check the browser options button, lower left of the browser just above the font resizing buttons. Highlight "Show Only" and make sure "music" is ticked.
geposted Sun 05 Mar 17 @ 7:33 am
You could also re-import the VDJ 7 database if that's up to date and working.
Simply delete (or rename) the current VDJ 8 database, then start up VDJ 8 and it should offer to import the VDJ 7 info.
geposted Sun 05 Mar 17 @ 9:55 am
Thanks guys. It was the "Show Only" checkbox.
geposted Wed 22 Mar 17 @ 2:02 am
