Topic: 3638 not closing properly
After doing a night close VDJ and its sort of still there in the task bar , and cant use Windows start button or anything have to force power off. It's only after doing a set, if I just open and close Vdj it will close normally..
geposted Thu 16 Mar 17 @ 10:45 am
Try this..
Whatever sound card you are using in Audio Setup of VirtualDJ, make sure its not the default sound card of your Operating System for both playback and recording.
geposted Thu 16 Mar 17 @ 3:17 pm
Oh yeah the default soundcard was XDJ-R1, don't know if will fix the closing issue til the end of the night though
geposted Thu 16 Mar 17 @ 3:31 pm
That seems to have fixed it, last 4 nights it closed properly
geposted Mon 20 Mar 17 @ 9:57 am
