Topic: Big microphone problem 8.2 and Denon MC6000mk2
Hi
First post after a few years of problem free djing but this one is driving me insane!!
On 8.2 with MC6000 mk2.
I seem to have lost the mic settings. Setting reset didn't work either.
At the moment I can switch on and off on the Virtual mixer but not the buttons. Well I can switch channel 2 off with the button with the mic plugged into channel one and I have lost the use of the echo..
Last week I had mic but it was on full gain and could only be controlled on the computer with no gain or switches working on the decks...
I am not the most computer savvy so if anyone CAN help please speak slowly..!!
Thanks, Peet
geposted Mon 20 Mar 17 @ 3:48 pm
The mics are hardware controlled and nothing to do with Virtual DJ. Sounds like your controller has a fault.
Thanks for replies.
They do connect as if I change a setting it affects the decks though not consistantly which is what's driving me mad!
I'll switch the mic/rec switch to usb then see if it helps!
does anyone know how to set up mic shortcut key for vdi 8
