Which plugin should I use to boost the bass on master when there's a need to compensate the lack of subwoofers and 12" or 15" full range speakers are all you got? Turning up the bass knob increases too high frequencies while there are much better technologies and algorithms out there which really squeeze out the lowest frequencies. Which plugin / VST would you recommend?
geposted Wed 22 Mar 17 @ 6:09 pm
You could adjust the filter thresholds so that the low frequency equaliser knob has a lower frequency cutoff?
geposted Wed 22 Mar 17 @ 6:20 pm
For more fine-tuned control you could also use EQ10 or EQ30 plugin.
That way you still have the regular equalizer available for actual mixing.
geposted Wed 22 Mar 17 @ 6:56 pm
In my opinion EQ30 is better.
geposted Wed 29 Mar 17 @ 9:26 am
