I'm very new to this board, but I have used Virtual DJ 7 and 8 before. I'm looking to download the 7 pro version so I can use it with my controller (I prefer it over 8), but I can't seem to find it on this site. Can someone help me out. If I subscribe monthly to Virtual DJ 8 will it work for 7 as well?
geposted Mon 03 Apr 17 @ 9:52 pm
the only way to obtain vdj7 is through a pro infinity license
geposted Mon 03 Apr 17 @ 11:54 pm
to clarify, only a full licence [paid in full] - not subscription, will give you access to v7 pro
geposted Tue 04 Apr 17 @ 12:54 am
Also, if your controller is a fairly new model, then it will most likely only be supported in the current software (VDJ 8).
VDJ 7 is no longer updated.
BTW you can use VDJ 7 skins in VDJ 8 if it's the appearance that bothers you.
geposted Tue 04 Apr 17 @ 5:13 pm
Sounds good. Thanks for the help all!
geposted Tue 04 Apr 17 @ 7:14 pm
how do i get virtual dj 7 pro
geposted Mon 21 May 18 @ 1:05 am
geposted Mon 21 May 18 @ 1:38 am
I really love virtual dj7, and all of the fixturtes inside it looks nic. if there is any improvement please try to iprove
geposted Wed 30 May 18 @ 12:53 pm
There will be no improvement to VirtualDJ 7. It is deprecated.
geposted Wed 30 May 18 @ 1:40 pm
hello who got a version that can work with linux
geposted Sat 22 Jun 19 @ 4:09 am
Nobody.
geposted Sat 22 Jun 19 @ 6:24 am
or depending on point of view
as windows insider program now uses a real linux kernel as well as android is using a patched linux kernel... anyone using remote or vdj on win10 insider
geposted Sat 22 Jun 19 @ 6:49 am
The linux kernel available in the windows insider build is independent of the windows kernel though, so it is not used when running VirtualDJ.
geposted Sat 22 Jun 19 @ 9:02 am
