Topic: Korg Nanopad2 mapping
Looking at the default mapping for the nanopad2 it looks like it simply has 4x the 16 pads (and the x/y things), but not the 6 buttons at the top
So it looks like maybe these buttons aren't sent as midi, but instead changes the midi sent by the 16 pads
In that case I guess I can't map the 16 pads to be the 16 pads in VDJ, and then use the top buttons to change pad pages
Is that correct?
geposted Thu 06 Apr 17 @ 11:12 am
You are correct, the extra buttons are hardware (dont send any MIDI), so not the ideal controller to use for Pad pages
geposted Thu 06 Apr 17 @ 4:15 pm
