Topic: Export Virtual Folders
Is there anyway to export the contents of a Virtual Folder to a txt file showing just the Title and Artist?
Thanks.
geposted Sun 09 Apr 17 @ 5:31 pm
You can export into excel yes. Just click on the little dot near the bottom right and export browser.
geposted Sun 09 Apr 17 @ 6:02 pm
The Export process will include all the visible Browser fields, so make sure you hide whatever you dont want to export
geposted Mon 10 Apr 17 @ 2:34 am
Thanks!
geposted Mon 10 Apr 17 @ 11:57 am
Just realised i should have said bottom left, not right. Glad you found it :)
geposted Mon 10 Apr 17 @ 12:14 pm
