Topic: cant get any headphones to work
jbustHome userMember since 2017
ive been through all the forums and tried everything, I cant get my headphones to play any sound what so ever when plugged into my numark mixtrack 3, any help/advice would be great
thanks
geposted Thu 13 Apr 17 @ 5:29 pm
A screen shot of your audio config usually helps in these cases.
geposted Thu 13 Apr 17 @ 7:24 pm
The Audio setup for Mixtrack Pro 3 should be ..
Master .... Mixtrack Audio (or similar name) WASAPI ... Chans 1,2
Headphones .... Mixtrack Audio (or similar name) WASAPI .. Chans 3,4
If yo dont get any sound in Headphones...
- make sure the CUE/Headphones Volume is high enough.
- the Mixtrack Audio interface is not the default device for playback of your OS
- Its set to quadrophonic (4 Speakers) mode.
http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
geposted Fri 14 Apr 17 @ 12:06 pm
